Old 08-20-2002, 07:31 AM
alacrity024
Rear-End Clicking..
Lately I've noticed a mild amount of binding through turns under power, but I figured "hey, it's a 10 year old Subaru.. what're ya gonna do?" But now there's THIS.. When I make a right-hand turn any sharper than about 70 degrees from a complete stop, I get a faint clicking noise from the right-rear of the car. It only happens when I'm powering through the turn--if i just glide through under momentum, there's no problem save for a tiny amount of tire skip if I've got it near the adhesion limits, which I don't do very often.
I'd just assume right off the bat that I need to take a good long look at my rear differential and at least maybe change the fluid. Does anyone have any other input? I appreciate it..
-Adam
Old 08-20-2002, 07:38 AM
red95svx
Sounds like you have a loose nut between the steering wheel and the drivers seat. Glad to help
Old 08-20-2002, 07:51 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Plug in the FWD fuse and test the turns.
I had that problem and it was solved by replacing the external tranny filter and tranny cooler.
There was much debate over why it worked or if it was a coincedence. I think we finally came to the conclusion that a clogged line increases the pressure in the tranny and it is enough to push past the solenoid C and partially engage the rear wheels at times it shouldn't, like slow speed turns. The further it clogs, the more rear wheel power is in place at slow speeds.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 08-20-2002, 10:03 AM
Ca$h
Could also be a loose/broken suspension bushing.
- Ca$h
Old 08-20-2002, 10:13 AM
Kamaleon
Question
i get a clicking sound on the left rear when i make a fast sharp turn from stop (to the left)..
i just noticed 2 days ago.. same issue here?
Old 08-20-2002, 11:25 AM
Clydesvx Clydesvx is offline
Way over-the-hill Member
I had a similar problem. It was a broken transmission mount. If you are getting a THUMP when accelerating and you let off the gas, it's probably the tranny mount.
Clydesvx
Old 08-20-2002, 05:52 PM
I_Alcyone_I
if you had rear wheel steering id say check the CV joint. But hey, I'd check it anyway.
