Old 04-24-2017, 08:17 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Check engine light
mine has just started to come on when engine temperature gets to "normal" halfway position, all fluids seem to be at correct levels?.
Any ideas from folks?.
Car has just done 159,000kms and is 1995 OBD1
Old 04-24-2017, 08:29 PM
lsupcar lsupcar is offline
Re: Check engine light
Check for codes.
Old 04-25-2017, 02:42 AM
SURTEESS's Avatar
ok will try youtube to find out how...
Old 04-25-2017, 04:22 AM
theflystyle's Avatar
There are instructions on the site:
http://www.subaru-svx.net/forum/forumdisplay.php?f=94
a thread with pictures:
http://www.subaru-svx.net/forum/showthread.php?t=63841
1994 SVX LSi
2008 Legacy 3.0R
Old 04-30-2017, 06:39 PM
Chucksta Chucksta is offline
Odd that the light comes on when you hit operating temperature, and, presumably, goes off after it cools down again. Traditionally, when the "Check Engine" light comes on, it stays on until the problem is rectified, or, if it was a transient problem, stays on until several re-starts have occurred without replication of what threw the first code..
Also, I'd be suspicious of the factory gauge. It's far from accurate, and factory designed to lie to you. It may be that you're running into a slight over heating issue..
