First Outback problem
Our 2010 with 160,000 miles has been a trouble-free car without one problem. Great gas mileage, no codes ever, As expected, on our second set of brake pads and our third set of tires. Oil change every 5 weeks, tire rotation every other oil change, etc. You know the routine.
Got my first flat tire in 15 years. Ran over over something in the road last night that gave me a blowout on the left rear. TPMS came on and I heard the flopping tire noise so immediately pulled over to the shoulder. No big deal, just put on the temp spare and on my way... so I thought. 4 of the lug nuts came off with no problem, one with lock. The fifth started to move and then got very hard to turn (with the factory lug wrench) Moved ever so slightly under hard pressure so I stopped before I broke a stud. Called AAA and they came out to assist. Mechanic put on a 24" breaker bar on the nut and slowly got it turning. After a few turns and no obvious movement, it was obvious that the stud was stripped out and turning in the hub. No way to get that wheel off and change it. Tightened it all back up and had it towed to my house, where it sits. I have seen cross-threading before and thought that is what this was. I have broken a stud or two, but never had one refuse to break and turn in the hub. How to you get the nut off or get the stud out without taking off the wheel first? You can't break a turning stud. Any suggestions.? I am sure this is not a first. Tires were rotated about 6,000 miles ago. .
Re: First Outback problem
oxy/acet torch... Burn it out... More than likely gonna do some damage to the finish of the wheel but it will come off. Either that or a high powered air gun to try and break it...
Tom |
Cut the lug nut or drill out the stud from the back. Either one isn't real easy but then you take the bill and drop it off at the garage who does (or used to do) your tires and rotations. That is what a moron with a impact gun will do so I wouldn't trust them fixing the problem either.
I don't think you can do that. I just looked at the wheel on our 2012 Outback. You can't drill it from the back because of the dust shield etc. The lug nuts are countersunk into the rim so there is no way to cut them. As you say it must have happened before to other folks. I would try calling a reputable wheel/tire shop.
P.S. Shish you do a lot of driving! Last edited by Blacky; 03-17-2013 at 12:58 PM. |
You can get it from the front, just drill through the center of the nut. Make sure you use a punch to get it started. Start with a small bit and gradually increase.
Found a nice little write up. http://www.greatlakes4x4.com/showthread.php?t=112066
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 03-17-2013 at 01:04 PM. |
Good write up, something to remember.
As far as the "idiots" who did this, it was Russel Subaru. In the 13 years I have been buying cars from them, or getting them serviced, I have never had a problem and have always been extremely happy with their work. I replaced the tires with OEM at around the time of my first brake job, as I wanted to keep the original ride.
Bob Hill, one of the few remaining SVX Master Techs, and the rest of the service staff have always done things right. They must have rotated the tires on this Outback at least 20 times. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-17-2013 at 02:37 PM. |
Come on now, it's a 2010. To rot off that quick he'd have to be driving in salt water on the beach all summer and salty roads all winter and parking in a heated garage.
ever been to Maryland and the DC area? They salt the roads with more salt than a brine tank.
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
John, sorry to hear about your dilemma, that is a first for me to. It could have been worse, it could have been your prized mean green sparkling machine on the way to Reading. Good luck my friend, and have Russell Subaru cook you up a nice breakfast while your there
1995 POLO LSI 76K MILES SOLD |
Talked to Russel Subaru over the phone. They are taking responsibility for it and giving me a new Outback as a loaner. I'll have AAA tow my Outback there there. Russel said they would also reimburse me for any extra towing charges.
As long as its there, I will also get a brake job, since I have 80K on the pads anyway. I am sure they will check everything else out very well. I would think a lugnut torqued down so tightly would have snapped the stud before it stripped inside the hub. We'll see... .
Now that's good old fashioned service.
