Adding an OEM Spoiler
Has anyone with an SVX without a spoiler, added the OEM one? I picked one up from a pick-n-pull and I’m wanting to put it on my car. .
1992 SVX LS 2002 Park Avenue 2008 328i convertible 1993 GMC C1500 W/T Last edited by svxcess; 11-25-2018 at 09:34 PM. |
Re: Adding OEM spoiler
The positions for drilling the holes are already molded into the trunk lid. Look from inside the trunk. My body shop did it back in 1993 when I bought my pearl one. The dealer threw in one to seal the deal. A $600 option back then.
And it cost me only $150.00 installed and painted black. .
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. Last edited by svxcess; 11-25-2018 at 09:35 PM. |
Awesome, ill have to check out the inside of the trunk. I wonder how hard it is? I think it would be cool to mold it into the body.
1992 SVX LS 2002 Park Avenue 2008 328i convertible 1993 GMC C1500 W/T |
Actually looks nicer when they mount it a few inches more to the rear so it almost hangs over the dack of the deck. Also remember you trunk lid is going to be extremely heavy.
Does any one have a pic of where the holes are for the spoiler? Theres a few different spots im seeing that it could be.
1992 SVX LS 2002 Park Avenue 2008 328i convertible 1993 GMC C1500 W/T Last edited by svxcess; 11-24-2018 at 10:24 PM. |
Ill look at mine in a minute, as I did pick one off a salvage car a year ago and I'm now in a paint class, so in the process of sanding now and removing all the plastic bits.
The Worm ![]() _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
Holes are just forward (above) of the trunk shock on each side. There are three
Re: Adding an OEM Spoiler
Drill holes at the indentations in the spoiler at the RED arrows. If you want to move the spoiler back, look at the instructions and photos in this thread by Bwana. http://www.subaru-svx.net/forum/showthread.php?t=64610&highlight=Spoiler” .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-25-2018 at 09:32 PM. |
in 1992, the OEM rear spoiler was an option, and added by the dealer prior to delivery. Here are the instructions. The dealer-installed spoiler instructions tell you to drill a 1/4" (6mm) hole from the underside of the trunk through the top and then drill a 1/2" (13mm) hole from the top back down. Actually, the instructions gave the drill sizes in mm, but this is approximated. Be careful not to drill into your car's body if you have the lid closed to drill the 1/2" hole. You can place a scrap of wood under the trunk when You lower it in case the drill bit goes through too far. Some members have moved their spoilers back approximately 2” back farther. If you already have a spoiler installed, the holes can be plugged with plastic plugs or with silicone sealer. The part number for the 4 nuts that hold the spoiler on is 902600009 A thin ribbon of strip “rope” caulk is installed around the two holes in the top of the trunk lid prior to mounting the spoiler. This keeps water from entering the holes, as it spreads and compresses when the spoiler is tightened down. I personally think it looks sleeker without the spoiler. Sealing and filling the holes and refinishing is a lot more expensive (almost $1000). More faithful to the original design. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-25-2018 at 09:27 PM. |
