how do i switch the temp readout to celcius?
just wondering........
i am only assuming there is a magic combination of holding/pushing buttons to swap the reading from farenheit to celcius...........? rob"i wish ONE of my svx came with the owners manual!!"m. ![]()
i'm too svxy for my car rob ![]() 92 ebony 4.44's rock !! ![]() |
There is a connector behind the drivers side kick panel, the one under the fuse panel. The same panel you remove to get to the diagnostic connectors.
I think it's a white connector with one wire, maybe two??? I also don't remember which is which, but I think unplugged will give F, and plugged will give C????
Remove the kick panel on the left side of the car.
Locate a white electrical connector with a SINGLE black wire going into both sides. Pull apart the white connector. Put the panel back on, start the car and turn on your climate control. The temperature is now reading in Celsius! .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Connected: Fahrenheit Disconnected: Celsius .
Thanks John, I had a feeling you'd help clarify my cloudy memory
thank you kind folks!!
![]() rob"jeez, you'd think subaru would do things easier than THAT!.....oh wait who am i kidding!!"m.
aha !!
thanks letitsnow ! ![]()
WTF? I started a thread like thi salready asking the same question and everyone was clueless!!!
When was that? I never saw it. If you don't get an answer at first, try posting it again by bumping it. Sometimes there are lots of posts going on and we don't get to all of them. I am glad you found out now. Good luck.
I forget...prolly a long time cause I've been on Celcius since last summer!!! Anyway it hasn't even been 24 hours and I am SOOOOO happy I can read my temps again!!!
![]() Rallyingrob thank you for asking this question! |
I am glad you got it fixed the way you want it. Don't be bashful, and if you have a question, ask, and ask again if needed.
![]() I would have thought you would now know how to read the temps in celcius by now. ![]() ![]()
Actually you can use a switch so that you can switch between celcius and farenheit... not my idea, but I have a small factory installed switch under the temp reading display in my 164L to switch between C and F
![]() ![]() -Pavan. |
Re: how do i switch the temp readout to celcius?
Hello,
Can we have picture for this, plz? My english compréhension si very bad Tx |
