Dealer rip off
Was going thru repair receipts for my 97 Ebony given to me by previous owner and this one still urks me. He had his rear wheel bearings replaced four times within 30k miles by the same Subaru dealership
10/18/07 replaced right rear wheel bearing $332.50 labor plus parts 10/31/06 replaced left rear wheel bearing $400 labor plus parts 4/08/05 replaced both rear wheel bearings $600 labor plus parts 11/21/03 replaced left rear wheel bearing $280 labor plus parts TOAL LABOR $1612.50 Its sounds like they just installed the bearings with the shipping grease, and or over tightened the lug nuts, how else would the bearings fail this many times whithin a relatively short amount of time and mileage. I would definitely not have paid them after the second failure and held them accountable, but this guy just dumped hundreds and thousands of $$$$$ in repairs into this car, and then he ended up having to sell it for $800 ![]()
1995 POLO LSI 76K MILES SOLD Last edited by SVX92-97; 10-12-2011 at 12:03 PM. Reason: edit |
Re: Dealer rip off
More than likely the hub needed replacing and wasn't done. It will cause bearings to fail repeatedly.
Re: Dealer rip off
on both sides? What would make both rear hubs need replacing
1995 POLO LSI 76K MILES SOLD |
Re: Dealer rip off
when the bearing goes bad and isn't replaced right away then the inner race spins on the hub marring it. i usually include this in the quote when doing subaru bearings. if it's not needed i don't replace it but 99% of the time it's needed, subaru should sell the hub and bearing as an assembly the same way every other car company does.
Re: Dealer rip off
Thanks for the info 92snowmachine
Re: Dealer rip off
So now does that sound like your going to have failures too? If the hub is bad you will . If the same Subi dealer did it then it sounds like they will fail again , unless the hub is not marred and he re packed the bearings the last time .
Re: Dealer rip off
Did a bearing on the Durango for my parents, other than having to hammer away at it to brake it free from the spindle for a solid 10 min using a 5 lb sledge, it's a piece of cake. All bolts in, the average person can do it. |
Re: Dealer rip off
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
Re: Dealer rip off
The only wheel bearings I ever replaced were on an old Dodge Dart and my 56 Chevy. U had to bang the outer race out from the hub and bang in a new one.
Re: Dealer rip off
how many members here have never replaced the bearings on their Svx's
Re: Dealer rip off
I never did it on my Pearly 80,000 miles
Re: Dealer rip off
you were lucky
Re: Dealer rip off
i've never replaced mine and have about 80k. have service records and they have never been done.
side note on bearings: i always used to buy the hub and bearing assembly for mid 90's civics and pop em in. ever since the earthquake in japan you can't buy the hub only the bearing. last time i checked not even honda had the hub. wherever those hub assemblies were stored or made must have been destroyed. |
Re: Dealer rip off
The only one I've had to do on any of mine was the FL claret that I knew about. It was a front bearing and I just replaced the entire hub with one I knew had a good bearing in it. However, I may have bearing noise in my silver. I just am not around it enough to have time to diagnose fully.
Re: Dealer rip off
All 4 have been replaced in the Laguna , only because he thought they might go bad . They are now Timken bearings
