programming new remote question
I got a new remote..still have one that works. When I program the new remote can I hit it 4 times to program and the other already programmed remote will still work or do I have to program both the new and old remote as if both need programming? Or since I have one remote already programmed, do I push the new remote only 2 times ? Answers much appreciated.
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod. Last edited by fasteract7; 01-08-2017 at 06:27 PM. |
Re: programming new remote question
Craig,
When you go into programming mode, it clears everything and you start all over. To program NEW remotes Turn the dashboard Security switch OFF (no light). Turn the ignition switch ON, them OFF. Leave OFF with key in ignition. Immediately and-quickly-repeatedly tap the dashboard security switch ON and OFF until the horn starts to beep. The system will indicate programming mode by a horn beep, the parking lights flashing and the control unit clicking. When in programming mode, press the remote button 4 times, which means... 1 remote: press the remote slowly and firmly 4x 2 remotes: press each remote button slowly and firmly 2x, for a total of 4x. So twice on your original and twice more on your new remotes. To complete the setup, turn the ignition switch ON then OFF and make sure the parking lights aren't flashing anymore and remove the key. .
Thanks for the clarification.
Happy New year to you !!
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod. |
I should post the instructions foe the original system. Backwards in every way, counter-intuitive to any logic and not user-friendly. And the passive arming was a nightmare!
No wonder they changed it 6 months into production. .
One of the sites I Googled had the passive arming system original programming..pretty Byzantine as you noted !
