Old 08-29-2006, 11:03 AM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
idle/rpm gone crazy!
This is really starting to bug me, and no one can seem to figure out the problem. And its getting worse. Basically, my car starts fine in the mornings. Or usually it does. Once in a while it starts out at a higher rpm until it warms up. It drives fine on the highway, shifts fine. (at least I think so, still new to this type car) And then once you get to your destination, or get off of the highway, while the car is in drive and your foot on the brake (at a light or stop sign)it idles at around 1200-1400rmp. If you put it in park or neutral it will rev up to around 2500 or higher rpm's. I took it in for service yesterday, it has a million and 1 problems, they told me my battery was bad and that might have something to do with it, even though it is 3 months old. So i took the car to get a replacement battery today, and after they put the battery in and I started the car, it was still doing the same thing, but the check engine light came on briefly then went off while in park. The car would rev up then go back to normal then rev up then back to normal. Then I drove the car home and it has been fine the rest of the day, but I know it will do it again the next time I drive it. They checked the alternator, it is checking out fine. They checked hoses and wires to make sure everything is connected and it all seems fine. When it does this I have to press harder on the brake and it feels like it travels to the floor more than it is suppose to, and they did tell me the rotors are bad, but I am replacing all 4 rotors and pads all the way around today. But this should not at all affect the reving of the engine. Any ideas?
Old 08-29-2006, 03:31 PM
immortal_suby's Avatar
Thread Killah
idle air control valve?
also Id check to make sure the throttle cable is not binding up. It is unlikely it would, but at least check it.
Locker Link
2015 BRZ Limited 6MT
Old 08-29-2006, 11:42 PM
Like Matt said, there is a high chance it would be the Valve Assembly Air Control.
Old 08-29-2006, 11:46 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Where are you in Ohio? Maybe we can meet up and I can help you out by trying some spare parts I have laying around and checking out a few ideas I have. Let me know.
Old 08-30-2006, 04:32 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I think he's located near Columbus...I saw from another thread.
1995 Subaru Svx L / AWD
Old 08-30-2006, 06:17 PM
Earthworm's Avatar
Meow!
Could definitely be a leaking vacuum hose which would explain the issue with the brakes.
Old 09-01-2006, 10:11 PM
Classic SVX
I believe we fixed the issue with the brakes (Unless a master cylinder is going bad), replaced the rotors and pads. The front pads litterally fell apart when removed. They seem to be working a lot better, the car is still having a problem with the idle, I am guessing it is a sensor, now its just a matter of finding which one.
Old 09-01-2006, 10:12 PM
Classic SVX
I am located in Columbus.
