Old 12-04-2016, 08:17 PM
Cotton's Avatar
Cotton Cotton is offline
Some Random Weirdo
Issues with idle after adjusting tension
I've been messing with the tension on my serp belt to get it right and I've ran into a problem.
I had thought I had an issue with my alternator, but Gene had pointed something out to me that leads me to believe it is from the idler pulley.
I had tightened up the belt a couple weeks ago and think I did it too tight. Had it stall out on me at a stop light and started it right back up and got it home. I adjusted the bolt on the idler pulley again and adjusted the tension. While it ran fine, at a low speed or idle it stayed way low and almost wants to shut off. I assumed it was an issue with my alternator as it is an original one and thought over tightening the belt chocked it.
I also think I have over tightened the bolt from the idler pulley. I have since adjusted it not so tight. I recently got a torque wrench and have read that this should be between 26-32 ft lbs. Is this correct or not?
The good news is I already had ordered an idler pulley because I want to have an UD pulley that I was going to do next year so I have it already. I intended to replace the alternator as well at some point.
Any ideas on what is going on and how to fix it? Here is a short video of it at idle.
https://www.facebook.com/tom.cotton....4716538888547/
94 SVX LSI- Rebuilt engine, 4.44 with trans cooler, Quick Change Shift Kit, SS exhaust with Magnaflow muffler, 08 STI Wheels, K&N Filter, and still adding.
