CDA and subaruparts.com
Just fired off the following parts list to cdasubaru.com to see what kind of pricing they can give me. Subaruparts.com online parts gave me the following, but I couldn't find an e-mail address to send an inquiry for better pricing nor did their web support form work. I wonder what else I should tack on to this already too expensive list?
subaruparts.com pricing Subtotal: $1,658.68 S/H: $165.87 Grand Total: $1,824.55 OUCH! x 2 806732150 Cam oil seal 32x45x8 13028AA120 Timing belt x 3 24233AA330 Sparkplug wire clip 24233AA340 sparkplug wire clip 13272AA031 Valve cover gasket (driver) 13293AA011 Valve cover gasket (driver) 13293AA020 Valve cover gasket (driver) x 4 800706630 Valve cover bolt-6x39.3x10 x 4 800706620 Valve cover bolt-6x29.3x10 21111AA033 Water Pump x 2 01040625A Thermostat bolt 21116AA020 Water pump seal 21114AA050 Water pump gasket x 2 20326AA120 Strut dust seal - front x 2 023512006 Strut self lock nut - front x 6 023510006 Strut self lock nut - front x 2 20320PA011 Strut mount - front x 2 20326AA000 Strut spacer - front x 2 20325PA000 Strut rubber stabilizer upper - front x 2 20322PA000 Strut dust cover - front x 2 20321PA010 Strut helper - front x 2 20325PA100 Strut rubber stablizer lower - front 20311PA001 Strut - passenger - front 20311PA011 Strut - driver - front x 2 20540AA090 Strut bolt - front x 2 20540PA010 Strut bolt - front x 4 20550AA010 Strut nut - front 26257PA000 Brake shoe passenger - rear x 2 26257PA020 Brake shoe - use 26298PA000 26257PA010 Brake shoe - pt370697 use 26298PA??? x 2 023512006 Strut self lock nut - rear x 2 031012006 Strut washer - rear x 6 902350013 Strut self lock nut - rear x 2 20370PA000 Strut rubber seat upper - rear x 2 20361PA020 Strut guide - rear x 2 20372PA010 Strut dust cover - rear x 2 20371PA000 Strut helper - rear x 2 20370PA010 Strut rubber seat lower - rear 20360PA001 Strut passenger - rear 20360PA011 Strut driver - rear x 4 20540PA010 Strut bolt - rear x 4 20550AA010 Strut nut - rear 062610110 PS O-ring 45167PA000 Radiator hose upper 45167PA020 Radiator hose lower x 2 091748004 Radiator hose clamp x 2 22690AA180 Oxygen sensor 57521PA000 Trunk strut passenger 57521PA010 Trunk strut driver x 7 57719AA020 Undercover bolts x 4 62310PA000 Window stabilizer - out x 2 62320PA000 Window stabilizer - in - passenger x 2 62320PA010 Window stabilizer - in - driver 86640AC040 Rear washer nozzle x 4 13230AA153 Valve lash adjuster x 16 13210AA020 Collet Valve |
parts
P.M.'ed you.
jesus.....
are you rebuilding the whole damn car??
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
I'd like to rebuild the whole car, but for now, I'll just settle for most of it. The bad news is, I might have to put all this off and get the tranny done first. 3rd gear is slipping more and more.
KuoH |
i have been there and done that.
i finally have my svx running good again so now i am focusing more on cosmetic stuff. powdercoating my calipers, getting the car painted, the interior redone...etc.
best of luck.
