Passenger Window won't Work from switchs
I am having trouble with the window only working when it feels like it. Any suggestion to slove the problem.
Tony
Re: Passenger Window won't Work from switchs
sounds like the regulator. got to get them from the dealer.
and you'll want to look up the instructions in the fsm for getting it out. If you follow the instructions it's pretty easy.
The window switches move +12v and gnd around to make the motor operate. If the motor sounds it might be the regulator. But when one of the two switches looses either a +12v or gnd it will not operate from either switch since they are wired in series. Best thing to do is apply 12v+ and gnd to the motor itself and bypass the switches to see if you have any movement. If you do, test the switches to see which one is not functioning and replace them accordingly
Tom |
Carefully analyzing the wiring diagram indicates that the ground involved in the circuitry is confined to the main switch on the driver’s side window controls. Locking out all the other window switches is accomplished by opening the ground. This action is common to all other switches. Although the system is designed with connecting wires between the master drivers switch to each of the other window switches the electrical function is not a series function. If it was, it would require both switches to be actuated at the same time to cause any other window to move up or down.
The purpose of the ground is to allow the 12 volts to reverse the current flow through the motor to cause a change in direction to lower and raise the window. If the passenger window basically does the same when controlled by the drivers switch and the passengers switch, I would consider the regulator. If on the other hand, it works fine with one and not the other, I would check farther on that particular switch… (Replace the danged thing) Back when the Honda moto was “we make it simple” SVX didn’t. ![]() My 2c worth… Keith ![]() Last edited by kwren; 06-13-2009 at 01:34 PM. |
t won't work from either switch and just some times it decides to work. Is the regulator able to let it work some times?
Mike what do you mean FSM?
FSM= Factory Service Manual
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Tom |
Window regulators have a gear inside them with some sort of cut out in the middle and some sort of (usually plastic pegs or plastic balls) mechanism in that cut out that apply the torque from the motor to the gear up to a certain amount of torque. When they go bad they start slipping some of the time followed by slipping all of the time. If the motor is running and the window isn't moving it's the regulator. If the motor isn't running it's not the regulator.
