View Single Post
Old 05-05-2005, 02:04 PM
red95svx
Originally Posted by Earthworm
Ok, I'll add that the power light will flash 16 times when you start the car. This is not the actual code but the notification that there is a code.
Follow the procedures in the codes section of http://svx-iw.com/ and that will tell you which code you are getting. When the resistor is bad or unplugged you will get code 11.
Ah yes.......I forgot that the flashes when starting are just to tell you there is a code.
