Originally Posted by SVeXy96
I have a 96 Cali SVX what are you trying to do?
Trying to order a set of under the hood labels, emissions and vacuum hose, for an eg33 swap into my legacy. Based on what the B.A.R. has told me, as long as the engine being swapped is the same year or newer and CA stickered too, even if it is an OBD-1 going into OBD-2 chasis, then the referee will sign off on the swap.
To facilitate the process, I want to have the labels and in place under the hood so the chances of it "failing" are diminished.
However, the dealer will not order the labels for me without a vin and id.
So the short answer is, I want someone to order decals for me
