Re: DIY glove box removal and blower motor replacement
First the support bracket needs to be removed from the back of the box area. There is a screw on the bottom of each end of the bracket. The light connection and clip will need to be undone.
Looking up from the bottom this is the motor assembly. Remove the breather hose and electrical connection.
There are three screws that hold he assembly in place, two of which also support brackets for electrical connections and wires.
With these removed, another elctrical support bracket needs to be removed to allow access to wiggle the assembly out.
I also removed the lower kick panel to allow extra wiggle room for the wires.
