Originally Posted by dragoontwo
No. Just the speed sensor. The speed sensor is identical to the SVX one. There is a 6 pin connector on the 6 speed for Reverse, Neutral, and DCCD.
Also if you are not connecting DCCD (which it is not required to hook it up, no damage will be done running without it) you can use the wiring from any other manual transmission to run to the reverse and neutral plugs and bypass the 6-speed plug if you have trouble finding the matching DCCD connector. That way you can wire the transmission in with factory connectors to the reverse and neutral switches and just leave the harness for the DCCD sitting on the transmission where it is.
