Originally Posted by longassname
Meaning the 6 speed uses the same harness plug to the main harness just with a lot less pins actually used and the speed sensor pins are in the same place?
Does it have pins for the leads to the dccd controller?
No. Just the speed sensor. The speed sensor is identical to the SVX one. There is a 6 pin connector on the 6 speed for Reverse, Neutral, and DCCD.
