Originally Posted by AlcyoneDaze
I GET MINE TOMORROW!!!
UPS tracking says so. Just a real quick question, when I unhooked all the hoses attached to the radiator, two of them spit out red ATF instead of green coolant. Does this mean I'll have to add a little more fluid to the transmission too?
I have just removed my radiator to have the top tank replaced in metal and know what you are referring to. I doubt that the small amount of fluid lost from the transmission cooler section will cause a problem, but you certainly should check the level as a precaution.
