Originally Posted by Suby Fan
the only issue with putting good rubber on the rear is with a FWD car... the back tires wear much slower then the front so if you get 2 tires and you keep the half worn tires on the front then you will have bald tires on the front and new tires on the rear pretty soon insteed of evenly worn tires
I never said it was the most economical. Only the safest and expert recommended method. Ideally you should rotate your tires every 3-5k so they wear at the same rate.
