Re: Custom Spring/Koni combo?
Originally posted by James Scott
Is Porter using the custom spring I heard about on another thread which you arranged to be fabricated for a few network members for $375. a set? I assume their $640. per set price for SVX Koni's does not include the springs ("high performance spring/Koni combo") you mentioned on my thread.
Let me know, Please. ...
THANKS!
I'm selling just springs which can be used with stock struts or with the Koni strut inserts. If you go with Koni, I'd recommend a higher spring rate than what my springs offer. You'll get even better handling than what you'd get with my springs. Porter has good springs in his soon to be available Koni strut/spring combo.
Mychailo
Visit my locker
