Re: Re: Re: NEW STRUTS - Which Kind?
Originally posted by rufus
Just to clarify, there is no welding involved in the installation of the strut insert. And the Koni inserts are about $600ish for the set, OEMs are around $400 if I'm not mistaken.
-Mike
oops. Sorry about the mis-info. I saw a picture of Porter doing some sort of welding on a strut body and assumed it involved the Koni inserts. If you buy online, OEMs are around $375. I thought that the Koni inserts were around $640. Not quite 2x I guess, but then there are the costs to install the Koni inserts into the stock strut bodies.
Mychailo
Visit my locker
