Originally posted by Sonar
My thoughts Harvey
So you don't see any sideeffects on this?
My first though was to put a potentiometer in parallell of the sensor, so I could adjust it to not trig the faultcode of a broken sensor, but maybe it's unnecessary.
/Sonny
Yes you could do that, to find the best resistance to use, as it is in parallel with the varying sensor resistance.
Can't see any side effects to it,other than the ATF light will be on, in this mode, so it can't signal a high ATF temp problem.
