Originally Posted by Trevor
Whatever you do, get the line pressure tested before giving up hope and committing yourself to big money.
If your starter was cranking badly, would you test battery voltage, or rush out and buy new starter motor?
Trevor, the line pressure is building properly. "Hard shift from the park position" lends me to believe line pressure is normal and increased beyond normal when the dropping reisistor is disconnected... Speaking from experience this is the case.
