Thread: Duty Solenoid C
View Single Post
Old 05-24-2010, 08:05 PM
Trevor's Avatar
Trevor Trevor is offline
Re: Duty Solenoid C
Originally Posted by bcpianoman View Post
Thanks for the suggestions. To clarify:
1. “having the same problem” does include still getting a code 24 and still binding;
2. there is no chance that Duty Solonoid C was not replaced. The mechanic did remove the rear extension of the transmission to replace it.
Since my initial post I inserted the FWD fuse. With the fuse installed I don’t get any binding and I don’t get the code 24.
Now what?
The situation is difficult to logically explain. The solenoid valve C is normally closed, so that when not energised full line pressure results in a closed centre clutch and binding. When energised as result of inserting the fuse, the valve is opened thus reducing pressure and releasing the centre clutch, i.e. a logical and normal outcome.
This then makes the TCU or associated inputs/sensors and circuits suspect. But why no relevant codes? However it does appear that the TCU is not providing proper control and opening of solenoid valve C.
In view of the transmission change, connectors and wiring must be suspect.
Trevor, New Zealand.
