View Single Post
Old 12-19-2003, 06:09 PM
Subafreak's Avatar
Subafreak Subafreak is offline
Superbeast
Originally posted by JoesSVX
Pinion bearing bolts. If you mean the bolts going through the axle shaftside bearing retainers on each side of the case halves and crown gear assembly: 17-20 ft-lb (sec 3-2, page 100)
Pinion shaft/ gear bolt. If you mean the bolts going through the differential case halves and into the crown gear: 43-48 ft-lb (sec 3-2, page 100)
Rear housing section. If you mean the torque converter case: 25-30 ft-lb (page 99)
Front diff section. Not sure what you are looking for here.
Hope this helps.
Um, not really.
By pinion bearing bolts,I meant the 4bolts on the pinion gear retaning plate.
By pinion shaft / gear bolt, I meant the one big nut at the other end of the pinion shaft that the gear with the park pin notches are in.
By rear housing section,I meant the part on the back of the tranny that has the center diff in it.
By front diff section, I meant the tourq converter case (25 - 30) Thanks
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs.
91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch.
78 BRAT (New toy) (Soon to be EJ22T powered)
90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car)
To many cars to spend time on teh web!
