Are you sure there are drains around the house? they may be clogged or damaged. Have you installed a sump pump that drains away from the house? How about rain gutters, downspouts, and extenders? Concrete in you crawlsapce won't do any good at all. Do you have visquene covering the dirt? It's ok to have water under the plastic. Too many variables to discuss from Alaska. Go to ASHI.com and look for a home inspector in your area.
- Home Inspector AK
Above post is not from NikFu.
