Thread: Axle Tips
View Single Post
Old 03-26-2003, 05:17 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Originally posted by lee
Beav,
I don't have to do this job (yet), but was wondering...are you referring to the trick I learned from you about the 3 bolts on the lower end of the arm? I know this will allow enough movement to pull the axle off the tranny. Does it then give you enough room to get the axle out of the hub?
tia.
Yup, it does. The two bolts he was referring to are the two that sit directly above the hub, tying the knuckle and strut together. They also provide the means for adjusting camber. No matter how well you mark them before dissasembly it would only be a stroke of luck to get them back precisely enough not to have changed the toe setting (camber and caster adjustments affect toe.)
