Originally Posted by showoval
The original owner had the same problem and said he had the system checked and it was full. I'm going to check the pressures this weekend and see if that tells me anything.
Ok, it's not pressure related, both sides were good. I believe the problem is electrical, I pulled the a/c clutch relay and found out that the compressor wire was not registering ground in the socket till I moved it at the compressor. Ok, one problem, repair wire still nothing. I believe I'm missing power to engage the relay in the socket to engage the compressor. I have one hot two grounds and one neutral, could it be the High pressure switch between the drier and condenser triggering since I sometimes have air at night or in the morning?
