Re: Suburban 1989 problems? some one can help?
Originally Posted by subeman90
issue number one: Look for a vacuum leak or since that is a diesel look for a vacuum pump issue. Also make sure the brake light switch is not going on and make sure the brake lights are not flickering as the vehicle goes down the road.
issue number two: Resistor blocks go bad. You will need to buy one. They sell for and average of around $15 US so that should tell you that these are a commonly replaced part.
Ok thanks alot.
Where is this vacum pump? The brake light is not going on when i driving. But its hold a little when its cold inside the cupe. But this is only right after i have start it.
I have just replace the Resistor blocks also. But still the fan switch wont work. And this is also new.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
