Originally Posted by Huskymaniac
I would listen to this guy.
And then I might start using better oil and changing it more often. But only if the old sender comes out looking like it is covered in gunk. Actually, if that is the case, you might want to go through the Auto-RX treatment cycle before doing a changeover to new oil and filter.
i do use good oil when i do my own oil changes...i use Mobil or Valvoline mostly Valvoline and i use the expensive fram filter the "heavy Duty" one...but the last couple times i have just gone to Firestone and had the oil changed...they use Kendall...
how much is it to replace the sending unit?
