3 ohm resistor mod doesn't work
I tried the WRX 3 ohm resistor mod, but the light stayed on. I will measure the resistance across the bag later today to see if it differs enough to require a different resistor. If all else fails, you can always pull the guages and remove the bulb behind the airbag indicator light.
