Originally posted by tat2skullz
Hey Kids~!
My mom has a 2001 Legacy GT with the factory Subaru alarm. Here is the deal... when arming or disarming, it uses the horn as it's signal (just like the SVX) but it is LOUD! Is there a setting that can be changed? Either to lower the tone, like the SVX, or disable the "beep" completely?
Seth, I think the answer is "yes" . . . at least you can do that (disable the horn) on the 2002 Impreza - I would guess that they probably share the same system.
Check the owner's manual under security system or keyless entry. The operation was very simple and took under 30 seconds to do - and if I could remember the procedure I would explain it!
If you can't find it let me know and I'll dig it out and post it.
