Originally Posted by dmnknightomega6
Sorry for a late resurrection of this thread.
So here is what we tried so Far:
Replaced coolant Sensor
Sprayed Starter fluid. (smelled Fluid on the tailpipe after)
I really think is its a sensor.
Since we have coilpacks, how do I test for spark?
What / Which Sensor can Cause a no start, and How can i test it with a voltmeter?
I would really hate taking this to a dealer....
Thanks in Advance
Any of the three timing position sensors not providing a signal, will prevent the spark and fuel injection, but if they were the fault it would give a check engine light.
Try starting it for few times, pull a plug to see if it is wet or smell of fuel to know if there is fuel being injected. Put a plug in the coil with the threaded end lying on metal, crank it over, see if there is spark.
Establish this and we can go from there.
