09-28-2002, 06:23 AM
Thread Killah
There is one male plug coming out of the car, you plug that into the female hole in your new radio. You may have to pull up the carpet a bit to change the routing of the antenna wire so it is long enough to make it to your radio - or you could buy an extension for it. You will not need to solder anything.
There is another female plug coming from the car which is basically useless. I remember hearing it is for the glass antenna that tunes AM radio but unless your new radio has this capability you won't even plug it into anything.
Locker Link
2015 BRZ Limited 6MT
