Re: Front suspension knock
Originally Posted by Tapani
I looked into this again - this time with a friend and on a lift with the weight of the cars on the wheels.
I am starting to lean on the struts themselves just like SVX_MY_BABY suggested below.
Found also, that the flex joint in the steering input shaft might be making sound. Not this one, though. The rubber is so soft that the dowels hit the slots they are in - they have contact marks on them. Under the axial rivets which hold the flex joint together are steel plates (like wings to support the rubber) - are these supposed to be completely straight? Mine are bent a bit and allow the rubber flex and then the dowels contact the steel slot. Am I making any sense here ?
Anybody replace this part?
Tapani
that's a "rag joint" it's supposed to break if you get in a collision. the metal discs are supposed to be bent and it should have some play. it sounds like yours is too loose. you can buy a new replacement disc at pretty much any auto parts store you just have to buy the correct size. to replace it take the whole assembly off and do it on a bench.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
