Originally Posted by 1986nate
The engine is quite easy to pull as is just about any Subaru if you have a fair amount of mechanical experience. I'd also suggest buying the updated rear separator plate and new style screws in case that is leaking as well.
Yes, I was planning on just replacing everything back there
So, to do that I need the rear main oil seal and the separator plate, right?
Here are the parts I'm seeing at SubaruParts.com
11831 - Oil Separator $12.99
G78603 - Rear Main Seal $9.45
B50604 - Screws $0.83
Anything else?
