Re: Might have a blown headgasket
Tony,
The stock thickness for the Cometic head gasket for the SVX is .066"
Bore is 98mm (stock), 100mm, 102mm are for re-bored cylinders.
The center or shim layer is uncoated stainless steel layer which can be adjusted in thickness to accommodate various requirements. This is in case of excessive head or block resurfacing to restore the original specs and compression ratios. You can have the MLS (multi-layer steel) gaskets made in the following thicknesses:
.027", .030", .036", .040", .045", .051", .056", .060", .066", .070", .075", .080”, .086”, .089", .092”, .095" .098”, .120" and .140"
https://www.cometic.com/i-24766993-s...bore-each.html
The Cometic head gasket Young Tom replaced in my polo back in 2009 is still perfect.
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
