wire clips {_}{_}{_} or [_][_][_] for coil wires . . . . . .
Dose are dem arite! I bot em a week igo (kustem ordur!) at da deelur. Had em in a li'l bag. Thru em away 'cus I thot dey wur trash! Jus twenee fighv buks. >>
Heh! Thanks for the good lead for my replacement parts. [Ya know I'll find 'em some day under the sofa cushion!]
Jim
