1. Check all of your vacuum lines
2. Check previous threads on Idle and 5 spd conversions
3. Have the timing advance at idle checked -- I'm wondering if you might have tweaked the timing belt when you moved the flywheel around during the trans mate up (PM Beav - he's the one who brought this possibility up in another thread). You should have 20 degrees of advance at idle.
Good luck
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
