Re: Window washer not working
Originally posted by DavieGravy
My front windshield washers aren't working and they're not clogged up with anything. I couldn't feel any pressure in the hoses going up along the hood into the sprayers. The pump motor isn't turining on when I pull the wiper lever forward. I checked the fuse and it's fine. When I got finished with my power steering o-ring, I sprayed the engine off with a hose becuase I spilt some fluid. Is it possible I damaged some wires going into the pump motor while spraying? I took a look at the wires going into the pump motor on the side of the washer fluid resevoir and they looked fine.
One other thing, I've been putting water in recently instead of washer fluid.
Thanks,
Dave.
It won't work if you pull the lever forward. It'll only work if you push the button on the end of the stalk. -- I learned from experience.
Randy Johnson
Mike Davis -- at Reading VI
