Originally Posted by crazyhorse
Light bulbs are a fuse of a sort. The elements are only just slightly more fragile than a fuse. I'd double check that the correct amperage fuse is in the holder. This is more a precaution than an actual cause.
While it's true that amperage blows fuses, voltage can, and will blow light bulbs. Over-volting can burn up all kinds of things, and make wierd things happen. While the car is down you should have the battery load tested. The consistent over-voltage could have hurt it.
yes sir, i just did that and the battery is good thank god lol
thanks for the info
btw, speaking of headlights, should i do the 9005 mod again or go HID?
