Re: Erratic brake performance due to rough idle?
There was a problem with some of these systems that would cause the ABS pump relay to stick "ON" causing the pump to run continuously, even with the key off, which would drain the battery. It could be a defective relay causing the pump to cycle long enough to feel it in the pedal, which would explain the noise... I'm not talking that it's making it run all the time, but like if the contacts were bouncing around causing it to like, pulse?
1986 VW Jetta
