Re: EGR question....
The 1992 US models did not have temp sensors either, unless they were fitted to meet California standards.
This does not mean that it will not throw a code for a fault in the EGR system. Somehow or another, the ECU can still throw a code (EGR stuck open or closed) even if the ECU wasn't programmed for a temp sensor.
Regardless of that, Bobby, you can cap or join the two fittings on the throttle body to keep them from leaking.
