Originally posted by gl1674
There are tools similar to compression testers, but they rely on compressed air and they measure the rate the compressed air leaks at a stationary engine. The benefit of air leakage tester is that you get to hear where the leak is - valves - inlet manifold, exhaust, pistons - oil sump or gaskets - see it in coolant.
Yes I tried to do this to my used engine and had some success. How do you hold the piston at top dead center so the valves stay closed?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
