More than likely you either picked up some dirt in the gap or cracked the porcelain of a plug or two. Possibly you may have disconnected the connector to a coil(s) while re-installing. To find the culprit disconnect coil connectors one at a time from each coil while the engine is running. If you disconnect one and the engine doesn't run worse you have found a cylinder that has a problem. Please be careful while doing this and don't place yourself in a precarious position, I'd hate to read that you were injured while doing this.
