Originally Posted by Mike621
Looking great!
What are you planning on using to offset the glass/top from the block? I have seen other designs that use the pistons or other engine pieces to create the offset.
I'm still thinking about it, but for example, what about the intake and exhaust valves? It will need to be lengthened somewhat. It can be fixed to the block by welding a bolts. I might also cut the top half of the #3 cylinder as there is an extra high section for the flywheel room.
