Re: Tie rod
Hello,
I replaced right side too. And, there were no problem to attach it. The left and right genuine part numbers are different, but they are the same and there seems to be no problem at all.
I adjusted the toe-in to almost 0 and did a test run. There are individual differences in preferences for toe-in adjustment values, but I prefer it as close to 0 as possible.
This is my impression after running about 100km today.
- The non-reactive area around the center of the steering wheel position has almost disappeared. At the same time, road irregularities can now be felt more through the steering wheel.
- Acceleration is now smoother. In particular, the distance traveled by coasting with the accelerator off has become so long that you can clearly see it. In other words, you can feel that the running resistance is reduced.
I realized once again the importance of this part.
FYI.
Noriyasu.
