Hello, everyone.
I replaced tie-rod (rackend) today. I was able to replace it without any modificaiton. It quite fine.
Please attached some photos.
555 rackednd is just 7mm shorter. but no problem. I used heat gun to softer boots because the diameter of the shaft it bit larger. It was snowing today and it was cold inside the garage so I turned on the heater.
I was able to easily install it by warming it up a bit.
A 32mm spanner is required to remove the original rack end without removing the rack from the vehicle. Furthermore, a 30mm thin spanner is required to attach the 555. I modified my old spanner to whittled it down a bit.
The wobbling of the wheel is gone and it feels very good.
I also removed other size of rackend and compare both. It looks quite same though part number is different.
34140PA000 Left/Passenger side
34140PA010 Right/Driver side
Pls note that Right size is Driver side for JDM cars.
I ordered one more for right side today.
I hope this information is useful to everyone.
SR-T490 Supplier 555 Sankei
http://www.sankei-555.com/tab/search...mno=OEM-NUMBER
