Thread: Dead SVXes
View Single Post
Old 05-18-2023, 03:15 AM
Noriyasu Noriyasu is offline
Re: Dead SVXes
Hi
I confirmed Wiring diagram and parts list again. sorry I made a misunderstanding.
22654AA060 drives fuel pump. not AT related.
Is your SVX has problem in fuel pressure? If register is no problem, it might reason of problem is fuel pump.
Is pump works ? Is there any sound from pump in the fuel tank when you turn on the ignition key (not start) ?
As far as I know, the fuel pump is often the problem, not the resistance.
It sits between my SVX's battery and the fender. The resistance value was 30 ohms in my SVX.
Last edited by Noriyasu; 05-18-2023 at 04:14 AM. Reason: correct misunderstanding.
