Yes, self diagnosis function is more easy to know get trouble code.
You can know the trouble code by blinking pattern of the check engine indicator.
Once you tie blue cable (it tie to body ground) into 2pin of 9pin black connector (B83). for example, if you get 2 times long blink and 3 times short blink, trouble code is 23. It means air flow sensor related trouble.
https://minkara.carview.co.jp/userid...ote.aspx#title
