Amr radiator warning
AMR WARNING!
While it is an awesome radiator in every way and a true drop-in, it is also thicker than OEM, which presents a problem which I discovered when I thought my fog light had burned out.
I found out today that there is absolutely no way to change the fog light bulbs with it installed
Perhaps removing the radiator supports will let you push the radiator back far enough to access the bulbs, but the entire bulb housing is covered by the radiator
I will post photos later but those who have the radiator installed can see the problem and comment.
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
